GT designer 3.. template issues
I created a template and have saved it in my library. it is an object. if i change for example an attribute say colour on the library editor...it does not change in the main screen editor. I have a number of the objects used in my main screen ( template(1)template (2)........) ......I would want if I change the template in my library that others templates in main screen changes accordingly too...someone please help!
That is not how it works.
The template (registration) function is so that when you use it you can change the attributes accordingly.
So if you place your template on the screen you only have to adjust the things you want to adjust.
