Ron_S Posted February 11, 2019 Report Posted February 11, 2019 I have a dosing system I did a few years back that has worked perfect ever since - but now they want to spoil it by adding 1/2 litres :) By this I mean; they enter the amount of chemical to dose on the hmi in whole numbers. ie 17 litres chemical 1 2 litres chemical 5 They press the dose button and my program jumps into action It checks each chemical for a positive number - if zero, it passes and then doses with the positive numbers. The counter meter gives 100 pulses per litre so every 100 pulses I increment the 'litres dosed' counter. I am trying to get the hmi/plc to accept say 17.5 litres so when it gets to 17 litres dosed it doses for another 50 pulses. (1/2 litre) The 1/2 litre will be a small bit of extra code within that chemicals dose. I have an HMI and plc set up on my desk to simulate the program but using 16 bit registers - it of course rounds it up or ignores the .5 Using 32 bit on say 17.5 litres just gives gobbdlygook numbers in the 2 registers that I dont know what to do with. I need the plc to read the 17.5 entered by the hmi as 17 in one register an 5 in another Any ideas?
collinsd70 Posted February 11, 2019 Report Posted February 11, 2019 Then why not just have 2 16-bit fields on your HMI, 1 for the whole number then another for the decimal point? Of convert from REAL to DINT/ INT and take your significant number off there? Regards Daniel
Ron_S Posted February 11, 2019 Author Report Posted February 11, 2019 Thanks I thought about the 2 separate data inputs - but we are dealing with operators here who complain it's too difficult as it is As soon as they miss a half litre by not inputting twice - they'll swear they did. It's hard enough getting them to put more than one chemical in. They put one chemical dose in and then come back to put another in even though I have told them it will automatically put them all in, in an orderly fashion with water between the two chemicals. The REAL to DINT etc, I have no experience of and that is probably the help I am asking for. Cheers
Veganic Posted February 11, 2019 Report Posted February 11, 2019 @Ron_S What is the maximum and minimum value you need to input? What do we do about say 17.4 and 6.8? What HMI are you using?
Ron_S Posted February 11, 2019 Author Report Posted February 11, 2019 The maximum value was set at 99 and I don't think they go near that - the minimum of course is 0 17.4 and 6.8 might be a possibility as they try fine tune some recipes. In fact they will want .250 (1/4 litre on its own for one recipe) The HMI on site is a beijers E1101 and I am using a E1043 to test with (both touch screen)
Veganic Posted February 11, 2019 Report Posted February 11, 2019 (edited) Thanks. This has two different problems: Problem 1 is operator input. Problem 2 is how you work on the data in the PLC. I have a few ideas for you to solve problem 1. No point working on problem 2 until this is done. See attached. It's for a 1101. Just try Project -> Run to see if it any of the ideas are of use. halflitretest.mpa.zip Edit : I would consider using pulses as your unit in the PLC and scaling to display in litres on the HMI. If you do want to stick to the half liter then go for the last option and just Div the D20 value in the example. ----[ DIV D20 K2 D30] D30 will equal your number of litres D31 will be 1 if there is an extra half litre or zero if there is no extra half litre. Edited February 11, 2019 by Veganic
collinsd70 Posted February 11, 2019 Report Posted February 11, 2019 (edited) Ron. I have made the following FB for you, it will convert any floating point to 2 seperate integers. I have bench tested on my Q-Series and seems perfectly adequate for what you need. Attached is the ASCII Import file you need plus a bitmap of an Instance working...... The logic is driven purely from the Real input value, if it changes, the calculations are completed over one whole scan and passed to the output parameters. The code takes advantage of the REAL_to_INT_E and reverse functions for generating rounded numbers in which the differences can calculate the signifjcant digits. Hope it comes in handy. iREAL (REAL); your HMI input value oWholeNumber (INT); the whole value from the REAL oSignificant (INT); the significant value (3 decimal places). oSign (BOOL); the sign (I have an absolute in there at the moment as I assume you always want positive). I would recommend you test that it works in the ranges required as ive only tested it to 500ish I think. Regards Daniel FB_MrPLC.bmp FB_Real_MrPLC_V1.asc Edited February 11, 2019 by collinsd70
collinsd70 Posted February 12, 2019 Report Posted February 12, 2019 @Ron_S See attached files above Regards Daniel
Ron_S Posted February 14, 2019 Author Report Posted February 14, 2019 Thank you all for your solutions - FB;s and HMi test screens but it wasn't what I really wanted I couldn't use the FB as I am using an FX1N in ladder and the slider was ok but too cumbersome. I just wanted the operator to input, say - 17.5 litres and the hmi to show 17.5 - but the D register to have a workable number. I have cracked it - or got a workable solution; I used the 'gain' on the hmi. I set it to 0.1 and decimal places 1 17.5 Litres was shown on the screen correctly and I got 175 in the D register. I can now work with that number. Thanks - hope it can be of help to someone else one day 1
Veganic Posted February 15, 2019 Report Posted February 15, 2019 Good idea - Keep it simple. The head-scratcher was trying to allow input in 0.5 increments only and not allow inbetween values which seems to be a lot more difficult than it first appears. None of the solutions I put up were ideal. In other matters - are you using the inbuilt recipe function of the E1101? It is really simple and really useful.
Ron_S Posted February 15, 2019 Author Report Posted February 15, 2019 Not in this case, they meddle with the recipes nearly every batch. They input the values from a hand written piece of paper. This hmi is a big step up for them. They were made to automate the dosing by the Health & Safety inspectors after an accident. You can see the type of chemicals and acids they use on my screenshot above. They used to use scaled buckets, drew the acid from a barrel and tipped it in by hand Until of course it went down someones leg one day. Hospital case and skin grafts. One step at a time with these guys.
Veganic Posted February 15, 2019 Report Posted February 15, 2019 Quote They used to use scaled buckets, drew the acid from a barrel and tipped it in by hand We can't even do that with cutting fluid these days.
