GBUK Posted February 13, 2019 Report Posted February 13, 2019 Hi, I'm a newbie to this software (HMI - NA5/Sysmac Studio), but does anyone know if when using Numeric "DataEdit" blocks, is there a way of calling up "variables" for Maximum & Minimum values ? In CX-Designer (NS screens) i was able to call up an indirect address reference for input limits, but there doesn't appear to be a similar feature on the NA HMI. Regards GBUK
IO_Rack Posted February 13, 2019 Report Posted February 13, 2019 They may have static values in them by default. You can overwrite them with a variable. 1
GBUK Posted February 13, 2019 Author Report Posted February 13, 2019 Thanks for your reply IO_Rack, I don't appear to have that option to overwrite these values. Initially thought it was because i was using "Variable" arrays, but have even tried it with single variables, same result. Is there a setting somewhere to allow me to implement this?? GBUK
GBUK Posted February 14, 2019 Author Report Posted February 14, 2019 Anyone else with any ideas??? I'm using a "Variable Array" list and want to use the same variable array list for maximum & minimum values. (see above) GBUK
IO_Rack Posted February 14, 2019 Report Posted February 14, 2019 There must be something wrong with your software or PC. Are you able to delete the current value? Can you input a static value?
GBUK Posted February 14, 2019 Author Report Posted February 14, 2019 The only thing it is allowing me to do is adjust the numeric value.
GBUK Posted February 14, 2019 Author Report Posted February 14, 2019 IO_Rack Is or has there been version updates, I'm currently using "Standard Edition 1.17" As far as i'm led to believe this is the current version for this software. GBUK
IO_Rack Posted February 15, 2019 Report Posted February 15, 2019 I'm running Version 1.25. You should run your "Omron Automation Software Auto Update" utility. I'm not sure if that was a limitation on that version.
innoaloe Posted February 17, 2019 Report Posted February 17, 2019 Correct, the older sysmac version won't allow you to use variable inputs for the Min-Max value. So, update it... I guess...
GBUK Posted February 19, 2019 Author Report Posted February 19, 2019 Have updated Sys Studio to V1.26.0.35. Still no user variable input to Max/min values other than numeric.
IO_Rack Posted February 19, 2019 Report Posted February 19, 2019 I'm guessing you are using Device Version 1.03. Are you able to upgrade via the Change Device dialog? 1
GBUK Posted February 20, 2019 Author Report Posted February 20, 2019 IO_Rack Great minds think alike, after downloading new software version, i randomly went exploring and came across the same thing, and Yeehaw! it works. No doubt this procedure will have to be repeated in the not too distant future. I have another question relating to this, when i (we) come to download the project to the HMI screen, does the screen require a "Firmware" update or is this taken care of with the software upgrade ? Your assist has been greatly appreciated. Thank you. GBUK
GBUK Posted February 20, 2019 Author Report Posted February 20, 2019 Question answered, system Firmware updates when it goes on line. Thanks guys. GBUK
IO_Rack Posted February 20, 2019 Report Posted February 20, 2019 Nice! Glad you got it working. I would imagine you could put an old firmware version in a new screen but probably not the other way around. I could be wrong. I've had no issues upgrading yet. 1
