Cristian Sulighetean Posted February 20, 2019 Report Posted February 20, 2019 (edited) Hello everyone, I am new to Mitsubishi PLC. My device is IQ-F series FX5u-80 and GX Works 3 to set up parameters using ST. I've tried numerous methods to implement a simple counter, however when I test the code, it doesn't add 1 to the counter, instead it adds a much more bigger value like 144. It is possible to use a pulse to increment the counter by 1 ? Thank you Edited February 20, 2019 by Cristian Sulighetean
kaare_t Posted February 21, 2019 Report Posted February 21, 2019 See below, a full example of a counter with pulse (PLS) to trigger the counting: PLS(yourTrigger, singlePulse); MOV(TRUE, K32000, counterMaxValue); OUT_C(singlePulse, C1, counterMaxValue); RST(rstCounterValue, C1);
Bryll Posted February 21, 2019 Report Posted February 21, 2019 Or if you want to use an integer (D-register) instead of a counter: INCP(Your_Trigger, Your_Integer); // Increment register on rising edge. RST(Your_Reset, Your_Integer); // Reset of register
Cristian Sulighetean Posted February 26, 2019 Author Report Posted February 26, 2019 Thank you, the increment register on rising edge works perfectly
