harii07@gmail.com Posted February 25, 2019 Report Posted February 25, 2019 Hello all I have OMRON PLC CP1E-E10DR-A. I installed CX programmer , where I unable to connect the PLC.Driver successfully installed. In the software , i unbale to connect, there is no option for choosing E10DR, Th software has option of choosing E20 and above. Can anybody help in this? Thanks
BobB Posted February 25, 2019 Report Posted February 25, 2019 The E10 appears in my list. When you select CP1E it defaults to E20 - roll up the selection box and you should find it.
harii07@gmail.com Posted February 26, 2019 Author Report Posted February 26, 2019 Thanks Mr.BobB In my computer I have installed CX Programmer V1.0. Is this correct software?. I donot find the option for choosing E10. More over My PLC is detected in Windows 10 OS but, The Cx Programmer V1.0 does not connect the PLC. Please suggest some idea. Thanks
gtsuport Posted February 26, 2019 Report Posted February 26, 2019 CX-Programmer is up to version 9.6x. If you have loaded version 1, it will not run correctly in Windows 10. gtsuport
IO_Rack Posted February 27, 2019 Report Posted February 27, 2019 (edited) As Bob mentioned, is it possible that you just need to scroll up? When you first open the dialog, it only shows 20 and up. Edited February 27, 2019 by IO_Rack
gtsuport Posted February 27, 2019 Report Posted February 27, 2019 IF he really has version 1 of CX-Programmer, that only supports CS1. CP1E requires at least version 8.2 or above.
harii07@gmail.com Posted February 27, 2019 Author Report Posted February 27, 2019 Thanks for your valuable reply. I try to install version 8.2 and above.
