Hello everyone,
I am new to Mitsubishi PLC. My device is  IQ-F series FX5u-80 and GX Works 3 to set up parameters using ST.
I need to implement a function that waits for a confirmation signal in order to continue to the next step of the program.
I though about another way by using a delay function instead of confirmation single for testing purpose
Sound's like you need STL (step relay or step ladder some may call it...).
In the IQ-F manuals, as i recall, there's a common overview of STL instruction.
More details yo can find in Fx3 series programming manual and it work's the same way
And the only difference was, that with FX3's STL end's with RET instruction.
With IQ-F end's with RETSTL.
But this is for ladder project.
Edited by glavanov
  • Like 1
Is it the complete program that is built using these "wait-tasks", or just a few functions? if it's only a few functions I would just jump them instead of creating a complete STL...
  • Like 1
The complete program is build on these wait functions, that's one way of doing it.
First and foremost I have a stepper motor to control, with a confirmation for position sensor and a busy sensor. I've thought about using the wait function in case I can not do it in another way.
The program mainly is a routine of the motor going in different positions and wait to receive the confirmation in order to make the next move.
You are describing probably 99% of PLC programs.
If you want to use ST language then I'd try to use a CASE statement.  If that doesn't work look at the other conditional and iteration statements (WHILE or REPEAT for example).
Like @Veganic writes, or just a simple ladder AND_E instruction that compares something (e.g. steppermotor_in_position) with "TRUE"... If it's a steppermotor value, just do "GT" instruction to check for greater than some value... "LT" = LessThan... and so on...
On 26.2.2019 at 1:19 PM, Cristian Sulighetean said:
Hello everyone,
Why you dont use IF ..... THEN ? like:
IF ConfirmationSignal THEN
     NextStep:=TRUE;
     ELSE
     NextStep:=FALSE;
END_IF;
IF NExtStep THEN
     NExtNextStep:=TRUE;
     ELSE
     NExtNextStep:=FALSE;
END_IF;
I've tried and it works perfectly for about 90% of the times. One thing that I need is to make the program wait for 2 seconds when I activate the vacuum to catch the workpiece .
I thought about verifying that the signal of the sensor that confirms the workpiece is 1 for more than 1 second if it is possible.
There is a big difference in making "the program wait for 2 seconds", and making "a sequence wait for 2 seconds". My guess is that you are looking for the second option (Making the sequence wait for 2 second). See image below for Timer (TON) functions. Image is straight from the manual.
Do you have e-Manual Viewer? In the FX5 Programming Manual, all instructions are available.
Try this:
Local Label:
StartBit                 Bit              VAR
TimerStart           TON           VAR
OKBit                     Bit             VAR
ProgramBody:
TimerStart(IN:= StartBit ,PT:= t#2s ,Q=> OKBit)
  • Like 1
