PaulKim1003 Posted March 6, 2019 Report Posted March 6, 2019 Hi guys, i am new to siemens, Can someone please tell me where i can find this tag? #Otomatik_ist_no and #Atanan_ist_no ,I dont know how to find these tags in the program. I have attached a pic of it. Thanks Paul Kim
Joe E. Posted March 6, 2019 Report Posted March 6, 2019 Click on "Network 1" in the code window and press Ctrl-F to open the search window. Then type in the name you're looking for. That will find where it's used in this FC.
Moggie Posted March 10, 2019 Report Posted March 10, 2019 The "tag" you have indicated is only used within the FC (internal Parameter). have a look at where your FC is used (FC207) and you will see the actual parameter that is passed to the "internal parameter"
Paul_M Posted March 12, 2019 Report Posted March 12, 2019 Click on the tag within the interface box at the top of the screen. Press Ctrl+Shift+F. This will take you to the first place it is used in the routine, press again for the next and so on. Ctrl+Shift+B will take you backward through the routine.
Joe E. Posted March 12, 2019 Report Posted March 12, 2019 7 hours ago, Paul_M said: Click on the tag within the interface box at the top of the screen. Press Ctrl+Shift+F. This will take you to the first place it is used in the routine, press again for the next and so on. Ctrl+Shift+B will take you backward through the routine. I'm going to have to try that. I knew it worked within the code window; I didn't know it worked from within the interface area.
