sst Posted March 14, 2019 Report Posted March 14, 2019 Hello I have a M251, running a webvisu. I have created a program to create a test report to a *csv file and store it on sd card. What I want to do next is to allow the user to download the * csv from the webvisu and not via ftp client like Filezilla. On codesys forums I see there are file up and download options for buttons (click behaviour) but they are not available in Somachine 4.3. One option I am considering is using the TCP server and steam the file manually from a button click. I dont want a ftp client as now the customer will then needsoftware on his pc, this plc is a portable test system and will be controlled by many different pc's. Is anyone aware of a simpler way to do this?
cHud Posted March 22, 2019 Report Posted March 22, 2019 Hi To download the file from the ftp server you do not need ftp software like filezilla You can go directly via web browser into the ftp site and just download the file. There are some features on codesys that somachine doesnt have like alarming and some others
sst Posted March 26, 2019 Author Report Posted March 26, 2019 Sorry for the delay, got side tracked. Thanks for the responce, I tried that but it will allow me to log in but does not display the folder tree (denied, even though I use the correct password). If I login via filezilla, it works fine. Must be a browser issue, will play a bit. Would be nice if they implemented a file download as I am using the webpage as the customers interface so dont really want them having to fiddle around when downloading files.
sst Posted March 27, 2019 Author Report Posted March 27, 2019 Thanks for the reply, I saw that. The ftp client fb's are nice but it would require the connecting pc to have a ftp server running. Not a big issue but the customer would be using different pc's to connect (dont really want to config them if i can avoid it). I will use this as plan B. I am going to experiment with the tcp server fb's, I should be able to stream a test file via a socket connection (activated by button). This should then directly download in the browser. I have done this is C# before so should work on the plc.
Ricardo Vargas Posted June 28, 2019 Report Posted June 28, 2019 Hello, What about if you the send the file in a e-mail , the M241/M251 has smtp so can attach and file to a document... Good luck!
Anbefus Posted June 17, 2021 Report Posted June 17, 2021 On 26/3/2019 at 11:29 AM, sst said: Thanks for the reply, I saw that. The ftp client fb's are nice but it would require the connecting pc to have a ftp server running. Not a big issue but the customer would be using different pc's to connect (dont really want to config them if i can avoid it). I will use this as plan B. I am going to experiment with the tcp server fb's, I should be able to stream a test file via a socket connection (activated by button). This should then directly download in the browser. I have done this is C# before so should work on the plc. Hi, I am facing the same problem, how did you solve it finally? Thanks!
