BITS N BYTES Posted March 20, 2019 Report Posted March 20, 2019 I am struggling to establish Ethernet communications between an IDEC HMI and OMRON PLC. Can ping both devices on the network, BUT HMI shows a communication error "ID:00h 0". Anyone have any suggestions how to resolve? Do I need to use CX-Configurator to setup a routing table, and if YES how to do it? Frustrated/Confused.
gtsuport Posted March 21, 2019 Report Posted March 21, 2019 From the HMI data sheet it looks like the Ethernet side is TCP. Ethernet port on the CJ2M-CPU33 is only Ethernet/IP and FINS. You would need CJ1W-ETN21 to communicate. Might be further ahead to use serial comms. gtsuport
IO_Rack Posted March 21, 2019 Report Posted March 21, 2019 I see the HMI supports SYSMAC(ETHERNET). Is this FINS? If so, then the PLC will need the network configured via CX Integrator. Here is a procedure I use for the older NS screens that don't have EtherNet/IP.
BITS N BYTES Posted March 21, 2019 Author Report Posted March 21, 2019 Thanks for quick response and app. note. Connection via Serial as gtsupport mentions works just fine. But I really prefer to go with Ethernet if I can get it working. Attached are extracted pages from IDEC manual showing that the HMI "should" be capable of connecting directly to the PLC. Setup procedure in IDEC WindOI-NV4 is somewhat confusing and missing anything regarding the need to use CX-Integrator as IO_Rack mentions. Have contacted IDEC Tech. Support and await reply. Meanwhile I'll continue working with "Good Ole Serial" Idec Specs 2.pdf Idec Specs 1.pdf Idec Specs.pdf
Jay Anthony Posted March 21, 2019 Report Posted March 21, 2019 Quote From the HMI data sheet it looks like the Ethernet side is TCP I didn't see where you picked that up. From all posts, it sounds like FINS UDP.
gtsuport Posted March 21, 2019 Report Posted March 21, 2019 Jay, You are correct, it is FINS UDP. Thanks, gtsuport
