Hello. I am trying to make a serial RS 232C connection between Schneider Magelis HMIGXU3512 and Omron PLC CP1E. However, there seems to be a communication problems between both of the equipment. I am using cable XBT Z9740 for the serial communication cable. The format used is 8.2.N for both equipment. The baud rate is 115200. No Flow Rate is choose. Anyone can help with this kind of problems?
@Jay Anthony is it a must to use the default baud rate? Because I am comparing my current settings with the old machine and saw that they used 115200, 8.2.N as their settings.
Then you need to change the settings on the CP1E PLC to 115200, 8.2.N to match your HMI. The cable above is correct.
I already set the format in the PLC & HMI to be same as mentioned before. However, the HMI seems to not communicate well with the PLC. I tried to created a dummy switch with the address set in PLC. However, there is no reaction at all from the PLC/Ladder diagram even after I tried to press the dummy switch. Moreover, the Comm lights and PHPRL lights on the CP1E keeps on blinking after I press the switch. Thus, I am a bit confused either my HMIGXU3512 actually have a correct serial communication or not with the CP1E.
16 hours ago, gtsuport said:
Change the PLC   Serial Port to Mode  Host Link.
You may have to change the End Code to CR, LF.
16 hours ago, Jay Anthony said:
gtsupport is absolutely correct.  Set the mode to Hostlink.:dance:
Will try to change the settings and see how it goes. Thanks for the helps. Really appreciate it. :-D
