marcinmrag Posted April 11, 2019 Report Posted April 11, 2019 Hello! I would like to measure cycle time but i don't have any idea how i can do it in cx-programer. All timers dosn't have feedback information about elapsed time. Can someone help me how i can handle this problem?
gtsuport Posted April 11, 2019 Report Posted April 11, 2019 What is the model number of the plc you are using?
gclshortt Posted April 11, 2019 Report Posted April 11, 2019 What is the accuracy you are looking to achieve? Depending on the PLC you can handle this a couple of ways. 1 - set the scan time and then count the number of scans. 2 - add the scan time every cycle Regards, Garry
Michael Walsh Posted April 11, 2019 Report Posted April 11, 2019 Here is a very simple way to do this: Use a clock pulse bit to increment the value in a register (D0 in this example) when a certain condition is true (W0.00). When the condition turns off, then move the value from D0 to D1 and set D0 back to 0. The value in D1 will be the cycle time in seconds (in this example). If 1s is not a fine enough resolution, there are shorter clock pulse bits: I don't show it here, but if you are using the D area for the registers, make sure to do a MOV &0 into D0 on the first scan as well to reset the current timer value to 0 at power up of the machine. If you need to be in the ms range and need it to be very accurate, the previous post is a good suggestion.
marcinmrag Posted April 12, 2019 Author Report Posted April 12, 2019 18 hours ago, Michael Walsh said: Here is a very simple way to do this: Use a clock pulse bit to increment the value in a register (D0 in this example) when a certain condition is true (W0.00). When the condition turns off, then move the value from D0 to D1 and set D0 back to 0. The value in D1 will be the cycle time in seconds (in this example). If 1s is not a fine enough resolution, there are shorter clock pulse bits: I don't show it here, but if you are using the D area for the registers, make sure to do a MOV &0 into D0 on the first scan as well to reset the current timer value to 0 at power up of the machine. If you need to be in the ms range and need it to be very accurate, the previous post is a good suggestion. thx I did this yesterday in similar way :). In sysmac studio or tia portal is much easer to do it.
