Milosh Posted April 12, 2019 Report Posted April 12, 2019 Hi all Is there any document which describe how we can set let's say analog input module via DM adresses. Which values of DM adddress corresponds to enable analog input, to set input range, to set mean value processing etc. Example: If i want to enable conversion on all inputs I shold to se #FF in DM20000. But is there any doc. which explains which address and which values we should to use for enabling, range etc. This is also interesting for some other modules, like CTS021... Thanks, Miloš
IO_Rack Posted April 12, 2019 Report Posted April 12, 2019 W345 - Analog I/O Operation Manual An easier method is to use CX Programmer. Double click the IO Table and Unit Setup, then double click the AD081 module. In the Parameters dialog box when you choose the setting, it will show you which memory is being used.
Milosh Posted April 12, 2019 Author Report Posted April 12, 2019 Yeah, it's easy for binary values. But how to know the values for Input1 input range setting, It's occupied 2 bits, which values corresponds to which ranges?
Michael Walsh Posted April 12, 2019 Report Posted April 12, 2019 Here is the manual: http://www.edata.omron.com.au/eData/PLCs/CJ1/W345-E1-12.pdf Section 3-5-4. 2
