Hi,
does anyone has program example of ethernet communication between FX5U (GX Works 3) and A1SJ71QE71N3-T (GX IEC Developer). I need to read and write in both directions.
Thanks
Hello Luka,
There are FB for the FX5 to read and write data to A Qna PLC's. You can download them from the Mitsubishi website.
However you can also use the Simple PLC communication Settings in the FX5.
Edited by Gambit
On 4/23/2019 at 9:28 AM, Gambit said:
Hello Luka,
Hello Luka,
As far as I understand, A1SJ71QE71N3-T module doesn't support QnA Compatible 3E Frame (i think that is for Qna built-in ethernet CPUs)??! (CPU is Q2ASHcpu-S1, doesn't have built-in ETH port.)
For A1SJ71QE71N3-T, I am using Fixed buffer protocol (library Eth_QE71_IEC_6)--pic in attachment.
The ethernet module of the QnA series supports 3E.
All you need to do on the QnA side is create a port
Edited by Gambit
