0608jai1990 Posted April 26, 2019 Report Posted April 26, 2019 (edited) Hi Everyone, I would like to know if two S7-300 CPU can exchange data via MPI protocol using X_Put and X_Get blocks. is it possible to test the data exchange via PLCSIM to verify. CPU1 = 313C-2DP CPU2 = 312 Please advise. Thank you. Edited April 26, 2019 by 0608jai1990
collinsd70 Posted April 26, 2019 Report Posted April 26, 2019 2 hours ago, 0608jai1990 said: Hi Everyone, I would like to know if two S7-300 CPU can exchange data via MPI protocol using X_Put and X_Get blocks. is it possible to test the data exchange via PLCSIM to verify. CPU1 = 313C-2DP CPU2 = 312 Please advise. Thank you. It is possible but you are limited to data amount due to the protocol and communication method. For 300 <--> 300 you are limited to 76 Bytes using either the GET/PUT or the SEND/RECV blocks. See here for further information. https://support.industry.siemens.com/cs/document/21537047/options-for-communications-via-mpi?dti=0&lc=en-AT Regards Daniel
0608jai1990 Posted April 26, 2019 Author Report Posted April 26, 2019 Hi Collinsd70, Thanks for the reply. I would like to know if it is possible to simulate it using PLCSIM, by using X_PUT and X_GET For an example, i would like to send 1 byte of data from CPU313C(DB1.DBX0.0...0.7) to CPU312. How can i simulate in PLCSIM? Thank you Best regards
collinsd70 Posted April 26, 2019 Report Posted April 26, 2019 23 minutes ago, 0608jai1990 said: Hi Collinsd70, Thanks for the reply. I would like to know if it is possible to simulate it using PLCSIM, by using X_PUT and X_GET For an example, i would like to send 1 byte of data from CPU313C(DB1.DBX0.0...0.7) to CPU312. How can i simulate in PLCSIM? Thank you Best regards I dont think this is possible (please dont quote me on that) as I dont believe MPI Protocol can be emulated in PLCSIM. The only method I can think of is to use 1 PLC and 'Net to PLCSIM' but you will need to change your connection type to Ethernet for this to work. In summary I think it will be easier to get the hardware and test as it will be in real world- or you can send me both your compiled projects and I will test across 2 PLCs for you.... Regards Daniel
0608jai1990 Posted April 29, 2019 Author Report Posted April 29, 2019 Hi Daniel, Thank you for the offer to test the program with your hardware. Here i have attached the files. Thank you Best regards Jai kumaran MPI Communication.rar
