Niszky Posted May 11, 2019 Report Posted May 11, 2019 (edited) Hi everyone, I need some help and ideas. PLC Type: CJ2M In my system, I have to track 3 palettes with sensors. A palette is defined by 3 bits. Then I need to identify the route the palettes have entered, learn this route, and recognize the color and workmanship we've produced. After all, I have to play back the process. How can I solve to store the bits of identified palettes and read back these bits later. I attached the palette turth. Thank you for your help. Edited May 11, 2019 by Niszky wrong picture attach and i want remove it
panic mode Posted May 12, 2019 Report Posted May 12, 2019 you only presented 3-bit value for color where are the tables with patterns for route, workmanship etc?
Niszky Posted May 12, 2019 Author Report Posted May 12, 2019 I have 3 different route to the different color chambers and plus 1 route to the pretreated part. I can solve the palette tracking, but I didn't know where and how I could store the 3 * 3 bits.
viman Posted May 14, 2019 Report Posted May 14, 2019 You can store those bits in retain area H (Hbit) so that the data stays there and doesn't get erased after powering off the machine. You can have H10.00, H10.01 and H10.02 for the first object, then start at H11.00 for the second and H12.00 for the third and so on. Just SET or RSET those H bits based on your parameters and you can later use them as conditions in your program.
