riandanualdy Posted May 14, 2019 Report Posted May 14, 2019 Hello, my name is Danu. I have a project to print label to SATO printer with CP1E from my weighing scale. I can print weight data in label, and i think i dont have a problem with SATO and weighing scale. My question is, can CP1E input the name of user with keyboard or HMI (especially NB7W (because i just have NB7W)) and save it in memory in CP1E? because i want print a label with name of user, weight data, and name of goods. And my second question is, Does Omron PLC have a type that has 3 RS232 or 1 RS232 with 2 optional board for RS485 (CP1W-CIF11) and RS232 (CP1W-CIF01) ? Thank you. Quote
gtsuport Posted May 14, 2019 Report Posted May 14, 2019 Danu, You should be able to "save" the name from the NB to D memory, then send that to the SATO printer. Your second question would be no. You could use a CP1H, with CP1W-EXT01 and a CJ1W-SCUxx module. CP1 family will only support up to two CP1W-CIFxx modules. gtsuport Quote
riandanualdy Posted May 16, 2019 Author Report Posted May 16, 2019 On 5/14/2019 at 8:17 PM, gtsuport said: Danu, You should be able to "save" the name from the NB to D memory, then send that to the SATO printer. Your second question would be no. You could use a CP1H, with CP1W-EXT01 and a CJ1W-SCUxx module. CP1 family will only support up to two CP1W-CIFxx modules. gtsuport How to input the name with NB and save it in to D memory in PLC? I Have CP1E-N30DT and include 1 RS232 port, if i want use 2 port RS232(for SATO dan HMI NB) and 1 port for RS485(For my weighing scale), what module can i use? Thank you Danu Quote
