Trimjohan Posted May 15, 2019 Report Posted May 15, 2019 Hi there! I had to replace memory in a sysmac C40H I also have a RS232 panel connected. It all worked together before memory change. I have upploaded the program again with CX-programmer. The sysmac works again, but the panel shows only "IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII" on the display. Cable is ok, it worked a couple of days before. Panel seem to have some kind of connection, if I pull the cable, it says "no host connection". How do I setup the sysmac again to work with the panel? Any tips or ideas would be greatly appreciated! Im a bit new to this system.
Wasan Posted May 15, 2019 Report Posted May 15, 2019 @Trimjohan Maybe you should check which data memory on PLC that link with text panel. Then monitor data that are "IIIIIIIIIIIIIIIII" or not. If yes you should check ladder diagram that which rung set data to display.
Trimjohan Posted May 15, 2019 Author Report Posted May 15, 2019 Hi! Thank you for the tip! Im a bit new to this, I have been looking in this file but Im not shure how that instruction would look. If I understand the system correct, there should be a rung that write some data in an adress, And that adress is only used for the internal rs232 interface. Which is then read and sent to the panel via the rs232 interface? the CX file is attached if you want to have a look. You will problably see it right away. autocutter_repaired.cxp
Jay Anthony Posted May 16, 2019 Report Posted May 16, 2019 Quote If I understand the system correct, there should be a rung that write some data in an adress, And that adress is only used for the internal rs232 interface. Which is then read and sent to the panel via the rs232 interface? There are no TXD and RXD commands in the program. Therefore the RS232 display is driven by Hostlink protocol which is a master-slave command-response type format. You need to be looking at all ASC commands for clues to how the display is driven (typically from DM's.)
Trimjohan Posted May 16, 2019 Author Report Posted May 16, 2019 3 hours ago, Jay Anthony said: There are no TXD and RXD commands in the program. Therefore the RS232 display is driven by Hostlink protocol which is a master-slave command-response type format. You need to be looking at all ASC commands for clues to how the display is driven (typically from DM's.) That sounds very interesting! I will have a look in the program. Just a thought: Do I have to set up the communication type in cx somewhere to make the Sysmac use hostlink on the rs232 port?
Trimjohan Posted May 16, 2019 Author Report Posted May 16, 2019 Just now, Jay Anthony said: The default setting is Hostlink. Thanks! I´m trying to find out if there is any missing settings in the C40H memory, which isn´t tied to the program code. Because I did a program backup with CX-programmer one week ago, the display was working then. Wiped all the PLC memory, put back exact the same verified program, and the display stopped working with the C40H after that. Do you have any idea or tip?
Trimjohan Posted May 17, 2019 Author Report Posted May 17, 2019 (edited) Latest Info: Apparently the displaypanel is an TERM402. I tried the program with another C40H, new cable and panel. Same problem. I noted that only when the panel is connected, the RUN light turns off. I even connected the panel with a new program, just to see what happens. the program only look simple like this and dont involve any panel config: -----I I-------------------------------------------O------------- And same tning happens. PLC stops RUN mode, and display only shows "IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII" So some setup or program information is missing in this program autocutter_repaired.cxp Edited May 17, 2019 by Trimjohan
viman Posted May 20, 2019 Report Posted May 20, 2019 That's an old controller and I haven't used it, but you are probably missing some parameters regarding the RS232 port. Baud rate, parity - those are not inside the program and, if your backup didn't contain the whole project, you need to set them again.
robertaung Posted June 14, 2019 Report Posted June 14, 2019 I am new here too , I would like to know cloud networking server and clients communication with PLC ( Omron ). I do want to know on MES 42 Q System ( Manufacturing Execution System ) interfacing with PLC ( Omron ), no idea which material out there avaiable to read and mind to share doccuments or leading to a link who can help.
gtsuport Posted June 14, 2019 Report Posted June 14, 2019 Trimjohan, Check the plc start up settings. The controller may be seeing the terminal as a programming device and starting up in Program mode. You should be able to set start up mode to Monitor. gtsuport 1
Trimjohan Posted September 10, 2019 Author Report Posted September 10, 2019 On 2019-06-14 at 1:38 PM, gtsuport said: Trimjohan, Check the plc start up settings. The controller may be seeing the terminal as a programming device and starting up in Program mode. You should be able to set start up mode to Monitor. gtsuport Thank you, that actually sounds like the true answer to the problem. So simple. I would really like to try it. Unfortunately I had to rebuilt the whole system with an Atmel microcontroller.
Trimjohan Posted September 10, 2019 Author Report Posted September 10, 2019 Thank you all for all the answers. Still I ended up rebuilding the whole system with an Arduino Mega in C++. Yes the safety functions are hardwired! I want to say thank you to Angeraer for the hostlink calculations. Here is a video of the result: https://www.facebook.com/watch/?v=466243297276584 Regards Johan
