Hello everyone,
I want to ask,, Does address mapping use this concept to do "remote i / o station" can be done? 5cee4ba16123f_WhatsAppImage2019-05-29at1
following the network parameter settings for CCLink and I tried to program with this ladder, is that correct?
You are doing it double right now.
You should either use the T0/ FROM/MOV instructions or use the parameters Remote input (RX)/(RY).
All the other parameters you can keep. (you should still set the stations). (The stations information button is still pink)
Alternatively instead using the CC-Link master in you can also se the CC-Link IE Field master in the system Q with a NZ2GF-CCB (CC-Link IE Field => CC-Link Gateway).
Then you can set the refresh parameters for each station. separately without having to program it in the sequence program.
Thx you mr. @gambit
On 6/19/2019 at 2:35 PM, Gambit said:
No problem. You have it working now ?
Yes Mr.@Gambit  I've using  buffer memory so I can address X100 and Y100 not overlap. Thx u,,
On 5/29/2019 at 4:08 PM, diraemon said:
