Milosh Posted June 5, 2019 Report Posted June 5, 2019 Hi all. I tried to start two identical Cx-supervisor runtime projects. Both of them started on different PCs. I noticed that after some time, some data (circle color) on one PC (runtime) were changed, but on second not. Why? I tried first to change the screen, and back, but the problem persists. Then I stop the runtime on "non-refreshed data" PC. After starting again data are changed. It looks like some refresh problem, but runtime projects are completely identical. Quote
gclshortt Posted June 5, 2019 Report Posted June 5, 2019 http://forums.mrplc.com/index.php?/topic/11888-cx-supervisor-hanging/ The above thread may help you out. Regards, Garry 1 Quote
Berti Baker Posted August 9, 2019 Report Posted August 9, 2019 Hi Milosh, If you're using V3.4 then upgrade to v3.5 as Readme lists bug fixes with animations and hanging. If you're running v3.5 and this sounds like a bug then worth raising with Omron direct on myOMRON. They are still actively fixing these things. Regards BB Quote
