I am a long time Omron user, but this is my first time using the Sysmac software, I want to compare the 16 bits of my array to zero, if any of the bits are on I want to turn on an output, I see the AryCmpNE and AryCmpNEV, but they have a seperate bit for each item in the Array, is there any way to do this without using Unions?
Thank you!!
Use the ArySearch function.
Knipsel.JPG.16e7947ff0cf96291f95368c0df1      Each Boolean in the array is compared to 1. If any bit in the array is 1 the output (FOUND) wil turn on.
  • Like 3
