Olyn Posted June 9, 2019 Report Posted June 9, 2019 Hi everyone! Can someone share their ideas on how should I start migrating my Mitsubishi program to Siemens PLC? What are the key points do I need to keep in mind when doing migration? Thank you!
Crossbow Posted June 12, 2019 Report Posted June 12, 2019 It will be a manual process, there is no way to convert. Best of luck with that... Might also get some useful responses if you said which Mitsubishi and which Siemens and what softwares you are using. We're not going to guess... 1
Donne Posted June 20, 2019 Report Posted June 20, 2019 there is no medium of migrating Mitsubishi programs to siemens, you can only write new programs in the siemens by considering your existing inputs/outputs, sequence of machine operations.
