Sudhy Posted June 16, 2019 Report Posted June 16, 2019 hi any one can help me about the procedures and tools to convert beijer e1101 to mitsubishi GOT 2710?
Bryll Posted June 16, 2019 Report Posted June 16, 2019 Contact your Mitsubishi dealer, they should have a converting software they use. You have to send them your E1000 project and you receive it converted to GOT format. Just be aware that you need to correct some things the converter can't handle. Good luck
Crossbow Posted June 18, 2019 Report Posted June 18, 2019 Never saw a converter tool for the E series while I worked there...
Ron_S Posted June 18, 2019 Report Posted June 18, 2019 There was a converter tool for e series below 1000 to above 1000. It was pretty dire though. Every screen had to be adjusted to fit correctly.
Crossbow Posted June 18, 2019 Report Posted June 18, 2019 Right, but a converter to GOT, that never existed that I know of. 1
Theo V Posted June 18, 2019 Report Posted June 18, 2019 Hi Sudhi, I've did a conversion from an E- 1032 textterminal to GOT 2508VTB.. once with a conversion tool from Mitsubishi but that worked out that only the alarmlist was converted. However the E1101 ia a touchscreen so it might work better. I've sent my file to the Mitsubishi contact in Holland and I got a zip file with the converted file back (free of charge) Just try it and see what happens. Worst case scenario you have to rewrite the complete application. Good luck, Theo V. 2
dunc Posted June 19, 2019 Report Posted June 19, 2019 i was lucky enough to be given a copy of the conversion tool for this from a mitsubishi rep. it converts certain E series projects to a GOT1000 project. you can then convert this to a GOT2000 project. it is very hit and miss though and takes a lot of fiddling about to get it to work properly. depending on the size of the project, its sometimes easier to just start again.
HMITouchscreen Posted June 26, 2019 Report Posted June 26, 2019 The Beijer E1101 is old operator panel.
Crossbow Posted June 27, 2019 Report Posted June 27, 2019 On 6/26/2019 at 9:46 PM, HMITouchscreen said: The Beijer E1101 is old operator panel. You'll find many questions on these forums about old product.
Geds Posted July 24, 2020 Report Posted July 24, 2020 This is interesting, does anyone know where I could download a copy of the converter software?
