Russ McKenna Posted June 24, 2019 Report Posted June 24, 2019 I am using FX5U-32MT/DS, FX5-40SSC-S and the PLC Open blocks. I am getting an Power-up procedure error status signal. Any suggestions on how to track this down? Or should I do away with block and replace it with Un\G# codes. If so what should I use to make sure the drives are ready? Quote
Russ McKenna Posted June 26, 2019 Author Report Posted June 26, 2019 You are correct. I did not try to accomplish the actual double posting. It was a snagĀ in the matrix. Please delete the second posting. Quote
