Hello guys,
Hardware :
            Laptop  with step7, WINCCFLEX  ip 192.168.0.223
            CPU 315  IP 192.168.0.1
            3x 8 input modules
            3x 8 output modules
           program in OB1 :  NO CONTAT I0.0 -> COIL Q0.0
I want to create a GUI in WINCCFlex  that contains a "start" button that when it's pressed to trigger i0.0 so I can turn on coil Q0.0 via laptop not a mechanical button.
So far I created a new empty project in wincc flex. Than  I went to connections and selected Ethernet ,for wincc runtime I ve put 192.168.0.223 and for station 192.168.0.1.
Than PROJECT -> INTEGRATE IN STEP 7 all good.
Now in winccflex under button events I chosed  "click" and action " setbit" and selected i0.0 from step 7 project.
COMPILE AND GENERATE everything but when I click button nothing happens :(?
Any help will be much appreciated!
thanks
If you want to use a "push button" or a "retentive button " from GUI to activate the output , you have to use a memory bit.
You may not activate directly an output from WinCC, it must be trough a memory.
