EduardoRmz Posted July 12, 2019 Report Posted July 12, 2019 Good afternoon. I made the migration of a Fanuc 90-30 system to the PacSystems R3XI family using Proficy Machine Edition. When the migration was made, some error messages appeared: "" C "block 'CONTROL' requires a rebuild with the PACSystem" C "Toolkit, then delete and re-add the block." "Instruction BIT_POS_WORD_30 found on rung 7 could not be converted." Reason: There is no room to allow new data to be converted. Check logic and make appropriate changes. " "Instruction BIT_POS_WORD_30 on rung 7 is not supported by the current CPU." I try to find a solution to the errors but I can not find an answer. Quote
