Connect the PLC FX5U and camera vision PIM60 SICK using TPC/IP
Dear all,
I have project. I need Connect the PLC FX5U and camera vision PIM60 SICK using TPC/IP.
So,I have never done TCP connection ever. Do you have any sample programs.
Can you help me.
Thanks all.
Looks like the camera only supports ethernet raw(json strings) or ethernet/IP.
So your options are:
  • Add an Ethernet/IP module to your FX5U config.
  • Create the Raw data protocol needed in de FX5 using pre defined protocol support.
  • Use a camera which supports the mitsubishi SLMP protocol like cognex - keyence etc
