How to map physical Input and output into variables type of Word?  It is easy in CX programmer with Mov 0 to  Inp_Word_0  (type Channel)
Global Variable  -----> Inp_Word_0 ,      Inp_Word_1     Type Word
                                      Out_Word_0,        Type Word
Example in NX1P2   map Input Bit 00 to Input Bit 15 to a Inp_Word_0,     and    map  Input Bit 16 to Input Bit 23 to a Inp_Word_1
                                     map Outpu Bit 00 to Input Bit 15 to a Out_Word_0,
You have to make a union.    See below:
First, make a union under data types like this:
Union1.jpg.ea3d03c445708928cfbe36c930f3e
Then create a variable that is of the type that you created:
Union2.jpg.301856bb548a4a18f5ab8b4934da9
Then use the variable as both a bit and a word like this:
Union3.thumb.jpg.9c1c1cd4543598857177890
You can ignore my comments about VB in the ladder, this was an example that I did for someone else.
I am using the above method:-), I thought there is a more simple method instead of writing bits to bits. Is there a way of assigning a variable at IO Table directly with the union variable?
Just assign a word variable to the input channel (in my example, I am using an input card) and then put a move instruction in the first rung of code that moves the input word variable into the unionVariable.word and done.
Of course output words would be at the very end of your program and you would be moving from the unionVariable.word into the output word.
