vnxxvii Posted July 21, 2019 Report Posted July 21, 2019 Hello PLC Users, I have recently final year project for my college. And i make PID instruction to control pressure and used VFD to control the pump. also used 4-20mA for Pressure sensor and 0-10V for VFD. But, i don't know how to use PIDAT instruction, please help me to understanding PIDAT Instruction, or do you have example ladder for my problem. Thank's :)
MPOLITIS Posted July 22, 2019 Report Posted July 22, 2019 Hi vnxxvii, In the attached file you can find some examples of how you can use PIDAT. There are two ways with the Instruction PIDAT and also with a FB. PID_Manual Section: PIDAT Instruction (see instruction help for more info). PID_FB Section:Example with Function Block. The demo is with CP1L-EM , Oprion Boards MAB221 and ADB21V1 Minas Politis Automation Enginner Demo_PID_v1.bak Demo_PID_v1.cxp Demo_PID_v1.opt
fasyaly Posted June 5, 2020 Report Posted June 5, 2020 Can I use this program for CP1H XA40DRA? And what about the program of analog input and analog output? Thanks.
IO_Rack Posted June 5, 2020 Report Posted June 5, 2020 2 hours ago, fasyaly said: Can I use this program for CP1H XA40DRA? Yes, the PIDAT(191) instruction will work with the CP1H. 2 hours ago, fasyaly said: And what about the program of analog input and analog output? What would you like to know? Please post a new topic in the forums.
T J SHARON Posted June 12, 2020 Report Posted June 12, 2020 Hi, I am using same ADunit channel ( 2502) for SV & PV in the PIDAT instruction. When the execution start the DIFU will save the current value as SV. I am suing AD081 and PLC read as UINT 0-4000. My doubt is Do i need to scale the 0-4000 to 0-4095 for the SV & PV.? PID_w_thrustercal.cxp
