Clear.Mind Posted July 26, 2019 Report Posted July 26, 2019 Hello guys. Could someone introduce me PLC/HMI lineup of GE. I need create a small system based on GE. It must contains of PLC (64 i/o), 1 remote I/O station (128 i/o) and HMI. I have exp with Mitsubishi, Siemens, Schneider. What is an analog of IQ-F FX5U or Simatic S1200 in GE? As i understand it is VersaMax Micro or PACSystems* RX3i? But i guess VersaMax Micro is too simple when Rx3i too powerful. Are there any selection tools for right configuration? What is an actual software for programming? Proficy Machine Edition using both for HMI and PLC? Quote
Steve Bailey Posted July 26, 2019 Report Posted July 26, 2019 VersaMax micro is probably insufficient for your needs, but there is a modular VersaMax option. Rx3i is also viable. Both are programmed using Proficy Machine Edition software. If you use a GE Quick Panel HMI, the program for it can be included in the same project as the PLC program. Quote
