BUJAR GASHI Posted July 29, 2019 Report Posted July 29, 2019 Dear all , Am trying to setup and condition of PLC in order to control analog output . so question is : how can i make that when i have signal on X001(K100) == D200 to increase value for 100 when i have signal on X001 and X002 (K50) === D200 to set valu ( 100 + 50) = 150 When i have signal in X001 and X002 and X003(k70) === D200 to set (100+50+70) = 220 but when i have X001 and X003 than D200 to set (100+70) = 170 So i have 11 inputs with different combination to control speed of VFD depend on inputs . Thanks . Quote
DaMro Posted July 29, 2019 Report Posted July 29, 2019 Hi, I think the simple method is: if X001 = ON then MOV k100 to some register f.e. D10 if X001=OFF then mov K0 to register D10 if X002 = ON then MOV K50 to register D11 if X002 = OFF then mov K0 to register D11 and same for all other inputs. finally add D10 + D11 + next registers and send this value to D200 Quote
nehpets Posted July 29, 2019 Report Posted July 29, 2019 To be honest, I think 11 inputs are a little overkill for what you are trying to achieve, this gives the possibility of 2^11 (1024) settings. How many different settings are required? Steve Quote
BUJAR GASHI Posted July 29, 2019 Author Report Posted July 29, 2019 actuali i need to make permutation so there are 5 combination with input . i created solution by mov command but there are a lot of combinatio . so am trying to controll VFD speed acording to X000 inputs . i thought if there is any solution do decrease line of code. Quote
BUJAR GASHI Posted July 29, 2019 Author Report Posted July 29, 2019 8 hours ago, DaMro said: Hi, I think the simple method is: if X001 = ON then MOV k100 to some register f.e. D10 if X001=OFF then mov K0 to register D10 if X002 = ON then MOV K50 to register D11 if X002 = OFF then mov K0 to register D11 and same for all other inputs. finally add D10 + D11 + next registers and send this value to D200 similar to what you mention already am workig to control vfd. i thout if there is any simple solution bacause there 5 combination by 5 in permutation . Quote
WattUp Posted July 31, 2019 Report Posted July 31, 2019 Most VFD have a multiple input speed selection settings. Maybe that would be easier? Or can you just use analog signal and a POT or HMI to set the output? Quote
