Asaddoris Posted July 30, 2019 Report Posted July 30, 2019 Hello everyone, I had seen a couple of threads concerning a serial module from Mitsubishi but still wasn't able to get the answers I needed, so I am no longer a lurker but a member. I have a Q06 PLC and QJ71C24N-R2 serial module, I am using a Sick IDM 260-100H scanner. The serial module has never been installed and currently the scanner is being interfaced with the GOT2000, but I am limited on what I can do there, so I bought the serial module in hopes of having more possibilities using it. So my goal would be to scan different bar codes such as a DM and 2D line bar code and have that data input into a register, from there I will be able to write the code of logic to manipulate that data the way I want. The problem is I have a couple issues. First when I scan the DM code, it inputs into the device register that I assigned in the auto refresh tab for that device, but not the entire code, I would assume this is just an issue with the allotted address assigned. Problem with that is I haven't been able to figure out how to extend this to reflect the entire string. The other issue I have is when I scan the 2D line bar code I get nothing. I am not 100% sure if this is due to the scanner and it possibly programmed for only DM's but I have replaced this scanner before and I just plugged it in and it started doing what the broken one had done, so I don't think this is the issue, but I will not rule it out. I have attached a couple screen shots of the switch setting and the auto refresh screen, but that is all that I had changed to the module parameters to get where I am at. Any information will be useful and appreciated.
