Hello,
Currently, I have Schneider PLC- LMC058 - LMC058LF42 which support Ethernet communication.
I want to collect data from this PLC to Database "MySQL".
In order to do this I have below options:
** I can use Kepware OPC to gather data, However, there are 2 issues am facing.
________[*] this PLC appears to be Telemecanique PLC instead of Schneider .. which is what I don't understand.
________[**] Kepware OPC doesn't support Schneider nor Telemecanique PLC ... that's what I found but not sure of it.
** I found Somachine SQL gateway which dumbs data to MySQL, however:
________[*] I can't find enough resources on how to use it.
________[**] It's asking for License, Is there a way to crack or bypass it?
________[***] Has anyone used Somachine SQL gateway to directly connect Schneider PLC to MySQL database.
My preference is using OPC server as it's the easier way, Hope I can find support on any of these 2 directions!
Thanks.
AK
The sql gateway is for somachine (codesys) plc's so it wont work for you
Kepware certainly has modbus drivers. All schneider plcs support modbus serial and/or modbus tcp/ip
And lastly dont ask how to crack software etc on this forum please
Edited by cHud
hi chud,
excuse my knowledge with Schneider PLCs.. but I don't understand why SQL gateway won't work, my plc is working on somachine v4.3.
Please advise if you used kepware on modbus drivers before.
Thanks,
Edited by amr kassem
