riandanualdy Posted August 7, 2019 Report Posted August 7, 2019 Hello, I done connect HMI NB7W series to PLC CP1E and just using input and output (0,0 and 100,00) and i can send data from weighing scale to PLC CP1E with RS232 communication. My Question is, if i want to send data from HMI NB7W to PLC CP1E but must input the new data first using number input in HMI NB7W, can i send a new data with RS232 communication (like send data from weighing scale to PLC CP1E)? so i can save the new data to memory in CP1E. I use NB Designer Software and CX Programmer software. If possible, can you tell me how to do it? Thank you Riandanu Quote
Crossbow Posted August 7, 2019 Report Posted August 7, 2019 The HMI has access to all memory areas in the CPU, including numeric. I don't get where serial comm and a weigh scale comes into this. If you want a third part device to talk to the PLC, it needs to talk one of the PLC's supported protocols. And RS232 is a single device connection, so if you are already using the RS232 port for the HMI, you can't also use it for another device. Quote
