BITS N BYTES Posted February 8, 2005 Report Posted February 8, 2005 Using a CJ1M PLC with an NC-233 position contol unit. Rather than create a custom screen for our position control units we want to use the Smart Active Parts Function within NS-Designer to adjust motion settings. The Smart Active Parts library includes a sub-folder NC_V1-3_E. When I select the NC133_233 folder and click "USE" I get the following message "The Smart Active Parts is upgraded version. Cannot apply it". Quote
Jay Anthony Posted February 8, 2005 Report Posted February 8, 2005 Convert the project to Version 5 or higher. Quote
BITS N BYTES Posted February 8, 2005 Author Report Posted February 8, 2005 Thanks Jay. Too bad I couldn't find this in the NS manuals! BTW The help function in nearly ALL OMRON applications really SUCK!! They open the front page of the PDF file - "NO HELP" is a better name. In some PDF files the search function doesn't even work [for example try searching for "macro" in V075-E1-03.pdf. 0 Results]. I HATE PDF DOCUMENTATION - Give me that good ole book. On the positive side - without this forum and the many contributors [including yourself] we would be LOST. Quote
BobB Posted February 9, 2005 Report Posted February 9, 2005 If you prefer the book print the pdf file like I do, when I need a printout. Quote
