pedroandre1998 Posted August 15, 2019 Report Posted August 15, 2019 I've been trying to connect my KEB f5 Frenquency Inverter to Onrom Sysmac but can't. I've generated the xml file from the Combivis (KEB program) but when I add the file to the xml folder for the Sysmac to detect I am greeted to this error(as seen in the attached file.).Does anyone have any clue on how can I fix or go arround this issue? Quote
