vijayvpv Posted August 20, 2019 Report Posted August 20, 2019 (edited) Hi all, I want to connect FX3G PLC to a network. So I have installed FX3U-ENET-ADP to the left side of the FX3G PLC using FX3G-CNV-ADP. Can someone help me how to change the IP address of the PLC according to my network IP address (let us take it as 192.168.0.50). So now I want to configure the PLC's IP address as 192.168.0.30. I tried using the FX-Configurator-EN but I could not establish a connection with the PLC through it. Here are the snapshots of the process I followed. But when I do the 'Connection test', I'm getting the following Error message. I tried to connect with both Serial port & USB. But it is showing the same error. I'm aware that there are lot of discussions happened in this regard, but I could not find the solution part to the problem I'm facing. Kindly guide me please. Best Regards, Vijay Edited August 21, 2019 by vijayvpv Quote
vijayvpv Posted August 21, 2019 Author Report Posted August 21, 2019 Guys, can anyone pls suggest where I'm getting wrong..? Quote
GreenMan Posted August 21, 2019 Report Posted August 21, 2019 Hi You do not need to use FX configurator EN. This software is for the FX3U-ENET module. You set up this ethernet option in PLC parameter\Ethernet Port. If you do not find the setting there you have to update your software. Good luck:-) 1 Quote
vijayvpv Posted August 21, 2019 Author Report Posted August 21, 2019 Thank you so much for the clarification GreenMan..!! So you're saying about the following Ethernet port setting, right? If it so, can you please suggest what is needed to set in the Ethernet Port open setting? Or can it be left as it is..? Regards, Vijay Quote
GreenMan Posted August 21, 2019 Report Posted August 21, 2019 Hi again This setting depends on what you wish to connect to the PLC. If it's only melsoft and a GOT HMI no change is needed. Quote
vijayvpv Posted August 21, 2019 Author Report Posted August 21, 2019 Oh alright, I got it..!! Thank you once again @GreenMan Quote
