cnels18 Posted August 20, 2019 Report Posted August 20, 2019 I'm getting this error while trying to add a timer to an existing program. I tried using a timer that wasn't used in the program but i still got the same error. The version i'm using is 8.98C
pcmccartney1 Posted August 20, 2019 Report Posted August 20, 2019 Assuming you are talking about the highlighted rung and the coil element with the M1. Timers start with a T??? and must be followed by K???? or a constant to define the preset value.
Ron_S Posted August 20, 2019 Report Posted August 20, 2019 You have posted a pic right over what you have entered Timers are coils and look like this. -------(T1 )K100 You then use done bits in your logic ----| T1 |---
cnels18 Posted August 21, 2019 Author Report Posted August 21, 2019 I was trying to use M1 to activate the timer. I tried T2K100, actually everything i could think of and i got the same error. They're using some of the timers but not all.
cnels18 Posted August 21, 2019 Author Report Posted August 21, 2019 Below the way i tried entering the values, and T1 is available because i used a search. Do i have to declare that i'm using this timer before i try to use it? i watched videos online and they just used it without doing anything. Is there a specific way i need to setup the program?
pcmccartney1 Posted August 21, 2019 Report Posted August 21, 2019 As previosuly stated, a timer instruction is a coil with the definition T2 K100.
cnels18 Posted August 21, 2019 Author Report Posted August 21, 2019 I know i'm asking for help but i entered it correctly, i don't think you look at it. How else can i enter a coil? I'm not using the application instruction.
pcmccartney1 Posted August 21, 2019 Report Posted August 21, 2019 (edited) It called syntax, please put a space between T1 and the K100 and try again. Ot type in T1 and then select the Edit button? Edited August 21, 2019 by pcmccartney1
cnels18 Posted August 21, 2019 Author Report Posted August 21, 2019 Thanks it worked didn't notice there was a space between them, I owe you a cold one.
