Victorybear Posted August 20, 2019 Report Posted August 20, 2019 (edited) Hi Have a TSX 47-30 with the memory fault LED "on" after a fault in the main power plant, the PLC have been without power 2 days. I try to find som manuals that shows what to do. Somebody have any info?? Edited August 20, 2019 by Victorybear
ratcliffe_ic Posted August 21, 2019 Report Posted August 21, 2019 Probably lost the program, but also watch out for faulty PSU AND lost program. If it was a black tab on memory module that would be a eeprom module but as it is a red one it will drop it's program.
acpi Posted August 21, 2019 Report Posted August 21, 2019 Morning, You have lost the program for sure. There's a battery inside the RAM cartridge memory and if it has never been replaced the program vanish each time you power off the plc. JC
