Pavel74 Posted September 2, 2019 Report Posted September 2, 2019 Hi!!! I'm currently getting started automation project based on the "FX5" Mitsubishi PLC. I already installed "GX Works3" software and download necessary documentation. Now, I try to configure PLC hardware in "GX Works 3" according to my requirements. Everything was clear until setting the "FX5-CNV-IFC" module. I can't find this module (FX5-CNV-IFC) in an "Element selection" catalog. Maybe, it is need to install some additional hardware support package? But which exactly? My question is how to added necessary hardware (in my case "FX5-CNV-IFC") in hardware catalog? Thanks. Quote
Inntele Posted September 3, 2019 Report Posted September 3, 2019 Hi, This module is not an intelligent, it's just a converter of bus connectors from FX5UC CPU to FX5U series modules. So this is not neccessary to configure it. Quote
Pavel74 Posted September 3, 2019 Author Report Posted September 3, 2019 Thank you. It means that, I will have to install that module (according to FX5 hardware manual) in real PLC, but not configure in "GX Works3" software? I was a bit surprised about that, because long time worked with Siemens PLC. Ok, now it's clear. Project compilation has error free. Thank you for your help. Best regards. Quote
