Hello,
I have problem, i cant connect 2 hmi to one plc. Maybe someone can give a advice how to do this.
The first HMI and plc communicate with RS422 connection. I want to connect second HMI with the same program as first HMI.
I am beginner with mitsubishi plc and hmi,so dont blame....
I added photo of plc and hmi
Thanks for any help.
No only serial. For ethernet you would only need a switch!!!!
You can find more info on the multidrop unit in the GT connection manual (mitsubishi) Chapter 19
https://www.mitsubishielectric.com/dl/fa/document/manual/got/sh081197eng/sh081197engab.pdf
If you want to use Ethernet you can also add an FX3_ENET-ADP and connect both HMI's.
FX3G(C) Ver. 2.00 or later
http://dl.mitsubishielectric.co.jp/dl/fa/document/catalog/plc_fx/l51/l51-a.pdf
Edited by Gambit
