FX3U (Made in China) Error LED when connect with FX2N-4AD
Hi, I need this help, I have a problem when connect my PLC FX3U (Made in China) with FX2N-4AD. When I connect the extension cable of FX2N-4AD to FX3U it turn off the RUN LED and ON Error LED.
But When I disconnect the FX2N-4AD from the PLC it operate normally. Does it because my FX3U made in China and my Fx2N-4AD made in Japan. I really appreciate your help.
Thank you
Hi
This error shows that there is something wrong between the PLC and the analog module. Check the connectors, if some small parts is stuck in it. Check also the total connection. If that do not work there is some thing wrong with one of the units.
I had that problem too.
New version of FX3U PLC is not compatible with FX2N-4AD. You must use FX3U-4AD
I had to use an old FX3U PLC and it works (I didn't find FX3U-4AD at local market)
Use Melsec F series selection tool to find what modules can you use (the FX2N-4AD is not listed anymore )
