akbar_torkashwand Posted September 11, 2019 Report Posted September 11, 2019 hello every body. I want to upload program from HMIGXU3500 . I have Vijeo Designer Basic v1.0 software Is it possible to upload program from this HMI.? I want to have back up file Quote
diraemon Posted September 11, 2019 Report Posted September 11, 2019 (edited) I think it's possible, like this faq I found at https://www.schneider-electric.com/en/faqs/FA303227/ and u can use USB type mini B to download or upload the program. Edited September 11, 2019 by diraemon Quote
akbar_torkashwand Posted September 11, 2019 Author Report Posted September 11, 2019 YES. I have this software. I connect mini USB between PC and HMI. Driver is OK in device manager. But I have this error when I want to upload program from HMI . What should I do? Quote
akbar_torkashwand Posted September 11, 2019 Author Report Posted September 11, 2019 this is about USB driver in device manager. Quote
NevergoldMel Posted September 11, 2019 Report Posted September 11, 2019 The HMI runtime must be Downloaded with the Upload allowed bit set on or you cannot recover the project from the HMI. Quote
cHud Posted September 13, 2019 Report Posted September 13, 2019 On 9/11/2019 at 2:18 PM, akbar_torkashwand said: YES. I have this software. I connect mini USB between PC and HMI. Driver is OK in device manager. But I have this error when I want to upload program from HMI . What should I do? This is not the vijeo designer software. This is data manager which is used to upload or download logged data. As mentioned before if the include editor project was not selected when the program was downloaded then the program cannot be uploaded Quote
SaukiBullah Posted January 11, 2020 Report Posted January 11, 2020 just try to uupload program with LAN cable and setting it in ip4 configuration Quote
Roberth Posted March 23, 2020 Report Posted March 23, 2020 Upload from HMI is only possible if you have selected the Include Editor Project check box and selected the Data file to Secondary Drive (CF Card) or Optional Drive (USB stick) prior to download the application into HMI.If the above has not been done it will not be possible to upload the application from HMI.For more information please see the video from below link :https://schneider-electric.app.box.com/s/0i8ea3p1hfubp74q1p4m Quote
