T J SHARON Posted September 13, 2019 Report Posted September 13, 2019 Hi to all, I have two queries about CJ2M-CPU13. 1) Can i use the in built serial port (RS232C) to the GUI or HMI? 2) Can i use the in built serial port (RS232C) to connect two CJ2M-CPU13s? I have only limited experience and knowledge in the PLC. I would like to see a step by step instruction video or tutorial notes. If any of you any information pls share and help me. Appreciate all help and thanks. Quote
gtsuport Posted September 13, 2019 Report Posted September 13, 2019 Welcome to the forum. Only one device can be connected to RS232. 1) Yes you can connect to a GUI or HMI. 2) Yes. Please see information on Serial PLC Link in the W472 manual. gtsuport Quote
T J SHARON Posted September 16, 2019 Author Report Posted September 16, 2019 As i said i am using 2x CJ2M cpus. I set 1st one as master and second as slave connected via serial cable ( wiring as per the manual). how can i check whether they are connected or communicating? Quote
T J SHARON Posted September 16, 2019 Author Report Posted September 16, 2019 Hi all, My serial cable as attached pic. I used this program as below. But when i use simulator i can see hexa output in 3100 & 0000. But when i go online, i cant see the output on 3100. My objective of this project is to give some inputs in cpu and get the output from cpu2.? Quote
gtsuport Posted September 16, 2019 Report Posted September 16, 2019 You will need to use the Data Link Area of memory for the communication to work. Data Link Area is CIO 1000 to CIO 1999. gtsuport Quote
T J SHARON Posted September 17, 2019 Author Report Posted September 17, 2019 hi Thanks a lot gtsupport. Do you have any sample program. ( sorry , i dont have that much experience in PLC linking). Quote
T J SHARON Posted September 17, 2019 Author Report Posted September 17, 2019 I am using 2CPUs. CPU1 is physically connected to ID231 , and CPU2 is connected OD232. I tried to connect them via serial comm ( CPU1 as master and CPU2 as slave) and connect laptop to CPU1 for programming. when I went online, CPU1 detects ID231 ( 0000) which is correct, but CPU2 detect also ID231 (0000) . i tried to change manually the slot , but shown error while uploading. I connected laptop to CPU2 and tried to get i/o info online, then OD232 detected. Any idea why OD232 wasn't detected while connecting CXONE to CPU1 and two CPUs are serially linked. Quote
gtsuport Posted September 17, 2019 Report Posted September 17, 2019 Please see the attached. Serial PC Link CJ2M.pdf Quote
