Hello
I'm quite new with GT Designer 3. I'm writing code for the GOT2107 HMI.
I have a few push buttons that works fine when pressed the switch lights up as you touch the switch.
But now I want a latching switch. Every time the switch is pressed the light on the switch should alternate.
How do I get a switch's lamp to stay on after pressing it?
Thank you
Marinus
You can choose if the button should react on the touch of the button or the status of a bit.
So if you use the status of the bit than the button is pressed when on and not pressed when the bit is off.
