Hello sirs , first sorry x my Spanglish , next i 'am newbie in plc's  (before work in asembler an C language) and i have a little problem
i work with MELSOFT GX DEVELOPER 8.98  and try the instruction FOR NEXT , and not works ,   please i need a little help thanks ,
waiting x solution ,  thanks  really  ...   ;)
thanks Wasan ,  X0 input for add 1 to D128 , x1 to decrease ,       D128  it saved in a temporally var D10 ,   output y7 flashes "D10" times ,  when finish Y0 on ,   now works but if you can simplificate , or write better , thaaaanks ,  regards from Barcelona ...
TEST.zip
@nandugos I have check your program do you need to flah output for D10 times but you fix them to 1000 time first? If yes I think you should use counter is necessary for count flash time. Please describe your program concept for more information.
