s.chehri Posted October 15, 2019 Report Posted October 15, 2019 Can l communicate between CP1H (through CP1W-CIF41) & CS1D ( through CS1W-EIP21D)? if yes, how? & Which software should I use? If no, how can I communicate between CP1H & CS1D? &which devices do I need to use? Quote
IO_Rack Posted October 16, 2019 Report Posted October 16, 2019 (edited) You can try this: http://forums.mrplc.com/index.php?/files/file/1009-fins-ethernet-master-slave-solution/ I know the CP1W-CIF41 cannot be used as a Master but it should be able to be a FINS Slave to the CS with the EIP21D. I'm not 100% sure about it though. The CS is fairly old. Edited October 16, 2019 by IO_Rack Quote
