Hello,
Omron NA project: I'm trying to create a button with image (see picture).
Unfortunately if I click on the image the button does not work because the image is 'above' the button itself. Is there a way to solve the problem ?
Thanks!!
The easiest way is to delete the button and then set a press event for the image.  To do this, show the Events and Actions window:
EventsActions.jpg.8defb5b86e5fcd7720e576
Then select the image and in the Events and Actions window, select Press as the event.  Then choose what action to take when the image is pressed:
Showpage.jpg.3b3a9abb28710a94d7562bb9fbf
It seems that this is a button that switches you to another page, so you could use the ShowPage Action, you would then just need to specify which page to go to.  You could also do many other functions like setting a variable to a specific value, etc.
  • Like 1
