From @SamuelT
Please, I want to know if you know how to communicate two plcs omron CP1H (master) and one CP1L (slave). The master CP1H will send 10 DM memories to slave CP1L.
Now I have this configuration:
CP1H MASTER
PORT: CP1W-MODTCP61 MASTER IP: 10.150.1.5
SLOCK: 1, DIP SWITCH PLC # 4 = OFF
CP1L SLAVE
PORT: CP1W-MODTCP61 SLAVE IP: 10.150.1.1
SLOCK: 1, DIP SWITCH PLC # 4 = ON
I use the modbus RTU function blocks, but the master PLC does not communicate or send the DM memory values to the slave PLC
Thank you very much for your reply
if you have any example program it helps me a lot
MRTU_CP1L SLAVE.cxp
MTCP CP1H_MASTER.cxp
  • Like 1
Are you trying to write 10 words from the CP1H starting at D0 to the CP1L and put the data beginning at D1001?
From the manuals that I see, Modbus register 1 is in memory location D1001:
ModTCP.png.0b8066e9b2ec711eae2178ee1d3d2
I would try to write values manually into D1001 in the CP1L and see if the value changes after the write FB is triggered (W10.00 on transition).
Here is the manual where I found the above table:
http://products.omron.us/Asset/CP1W-MODTCP61_SetupGuideManual_EN_201207.pdf
Here is the guide for the Function Blocks that you are using:
https://www.support-omron.fr/telechargements/documentations/2017-03-09%20-%2011-41-14%20-%20105486908/MRTU_CPU_Master_E.pdf
