cyrus Posted October 31, 2019 Report Posted October 31, 2019 hi dears, I have one CS1D omron Redundant controller ( CP65H) that must be connected to NS15 Touch panel. I want to use Ethernet for connecting HMI and CPUs (CS1D-ETN21D). I have one question. for NS15 we can use CX designer and sysmac studio? is it true? which one is better? what is your recommendation for HMI software? Thanks.
cyrus Posted December 9, 2019 Author Report Posted December 9, 2019 Thank you for your reply what is omron solution for hmi redundancy?cs1d with ns15 id there any manual for it?
IO_Rack Posted December 9, 2019 Report Posted December 9, 2019 Just now, cyrus said: what is omron solution for hmi redundancy? For all practical purposes, the HMI is a client to the PLC. The PLC in most cases does not reference the HMI. So you could just duplicate the HMI program to another HMI. You would just have to change the IP address (and FINS node if using FINS protocol).
