Ctor Posted November 21, 2019 Report Posted November 21, 2019 (edited) Hi all, I would like to validate the "FINS write protection", but I would need to include the computer of the company in the nodes excluded from this protection. However, I have tried it setting Node=IP.node, Net=0 (as local) or Net=1 (net of the ethernet port); but it is not working... Certainly, it is "working", only if I use a UDP connection with other software than Cx-Programmer (as Etherway, for example). But obviously I need to use Cx-Programmer (not UDP). Thanks a lot! Edited November 21, 2019 by Ctor
Ctor Posted November 21, 2019 Author Report Posted November 21, 2019 Ok, I have detected it. The connection was using E/IP, I have to connect the Cx using normal Ethernet, so, the PLC will accept me as Exception for the FINS write protection.
